Old 02-28-2023, 03:04 PM   #56 (permalink)
Xist
It looks like the crankshaft position sensor is under the lower timing cover, which is held in place with 10mm fasteners.
There is an 8mm Phillips hose clamp holding the filter housing to the throttle body. I loosened it quite a bit, but the hose clamp didn’t seem to get any looser.
However, that seems to be the problem.
As far as I can tell, the air temperature sensor is in the airbox, and I already disconnected it.
