Old 03-04-2023, 01:29 PM   #3 (permalink)
cRiPpLe_rOoStEr
Most likely a slightly taller tire won't be so bad at all, considering the low-end torque of that engine is quite good, as you won't be towing. Also considering it won't go hardcore off-road, maybe a slight increase to ground clearance which would be provided by taller tires won't be so relevant. On a sidenote, isn't there any taller rear-end which could be swapped, to allow a similar performance with smaller tires which would decrease riding height to improve aerodynamics while on highway?
