Old 03-10-2023, 03:31 PM   #33 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
4kw @ 120v =33.3333 amps then add some for inverter losses so under 50 amps. 4kw @12 volts =333.3333 amps power in. Like > 2 gauge fairly short battery connections and some serious battery storage like a volt battery pack. Bet it cooks itself at those loads
Hmm, but no mention over on the diysolar site of this. Must be chineseium
yikes that a good point on the 12v amps being no bueno. I've also heard the chinesium ones can be much lower on actual efficiency when tested as well. Some times like around 80% efficiency but it all depends on load and duty cycle. Sounds like a 48v system makes a lot of sense if you get into larger stuff.
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
