Old 10-19-2008, 07:26 PM   #8 (permalink)
stryker16
Mr. Taco - '01 Toyota Tacoma SR5 4x4
90 day: 16.18 mpg (US)
Originally Posted by trikkonceptz View Post
I understand that the scangauge can be calibrated, but since it is plugged into your OBT port, has your ecu been recalibrated also? or does it still think you are running your factory setup?
Are you guys sure that just adjusting the SG settings is enough?
The scangauge doesn't change ECU settings. There are no codes on my ECU and it has always run factory settings. The MPG is down to about 20 in the city so I think it is working fine now.
