Old 03-13-2023, 01:17 PM   #2 (permalink)
freebeard
A pusher trailer.
This aero setup helps with the trailer’s other headlining feature, its drive system. Located under the sleek body is a self-propulsion system. An electric powertrain is found underneath the camper which houses an electric motor and a 80 kWh battery.
If that sounds awfully familiar, it’s because this concept is currently being worked on by Airstream and Dethleffs. Both companies have taken camper designs, outfitted them with self-propelled EV gear with 80-kWh, and are marketing their campers as having similar benefits.
aerohead (03-16-2023)
