Whole House Generator $1,700.00 and Portable
12,500 watt Westinghouse from Home Depot "DUEL FUEL" Generator 50 Amp power cord found a 50' cheaper than shorter ones. 50 amp plug box added to Junction Box with a 50 amp fuse with power cut off slide plate. Converted Duel Fuel to Nat Gas with an additional valve for Nat Gas hose goes where Propane hose went. Watch Florida Guys vids about fuel requirements per day and you will see why you want to convert to Nat Gas. Plenty of Utude vids to show how to do this for your house. All you lose when moving to new house is Junction box plug and 50 amp breaker less than $200. Luckily have not had to use it since "Snow-ma-gedon" in Texas!
