Old 03-16-2023, 11:36 AM   #49 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
4kw @ 120v =33.3333 amps then add some for inverter losses so under 50 amps. 4kw @12 volts =333.3333 amps power in. Like > 2 gauge fairly short battery connections and some serious battery storage like a volt battery pack. Bet it cooks itself at those loads
Hmm, but no mention over on the diysolar site of this. Must be chineseium
This is why I decided to go 48V for my Ambulance / RV conversion. Once you start pulling any real loads the current and wire sizes get crazy. Even running a small electric heater as a test through a 2000 watt inverter put a huge sage on my 12 V battery voltage in my old campervan. (2 x 6V / 200 amp golf car batteries in series) 12V is fine for running a small super efficient fridge and charging some portable electronics but not much beyond that.
I also didn't want the hassle of stringing together 8 12V batteries when I could buy much more compact 48V server rack batteries. It is also very hard to find a 12V charge controller that can handle 1800 watts of solar.
This isn't a surprise though. It is almost universally agreed that cars should have moved from 12V to 24V 40 years ago and should be 48V today.
Originally Posted by RoadRaceJosh View Post
My inverter/charger is a Cotec that was discontinued. The Victron MultiPlus looks to be a good choice. https://www.victronenergy.com/invert...48v-800va-3kva
I'm 95% sure I'll be bying a 48V Victron Multiplus. That 5% uncertainty is whether I want to upgrade to multifunction unit. They take less space, and make the wiring cleaner but also cost more and give a single point of failure.
