Old 03-16-2023, 10:07 PM   #10 (permalink)
Xist
90 day: 34.37 mpg (US)
DIY an oil leach with a 2L soda bottle, tubing, and a shop vac!
In Chris Notap's second video he says to put the catch container inside the shop vac.
You make a funnel from the top of the bottle, cut a hole just big enough for the tubing, which you feed through, stick the soda funnel where the vacuum hose goes, run the tubing into your waste container, feed the other end into whatever fluid you need to change except for gasoline, and you turn on the shop vac!
BamZipPow (05-02-2023)
