Old 03-18-2023, 06:04 AM   #446 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by FlashStopFall View Post
Once again, a little time solved my problems. I didn't realize that the code would simulate sensors by default - after finding and turning it off in settings, everything works.
That's more due to my not properly vetting the code before posting it.
Sensor simulation is a development feature, as you've guessed. This must be turned off before MPGuino can read VSS or injector signals, as sensor simulation overrides these inputs. Either leaving out this feature altogether at compile time, or manually turning it off via the sensor page in MPGuino (if it was compiled in), will enable MPGuino to read VSS and injector signals.
I think that Jeeps have slightly different fuel pressure specifications than the Dodge I used for development. 49 psig for fuel pressure, IIRC. My Dodge used 58 psig.
The Following User Says Thank You to t vago For This Useful Post:
FlashStopFall (03-18-2023)
