Old 03-18-2023, 02:43 PM   #18 (permalink)
Xist
90 day: 34.37 mpg (US)
You guys started with #1, not the new posts?!
Weird!
Replacing the Civic oil pan?! Are you sure?!
I did that many years ago!
With the Accord oil pan, I just remember having difficulty maneuvering the pan under the frame rail and everything, but as I also posted in #1,
JR has a video using a commercial one[...] When he pulled the drain plug only a drop of oil came out, so that sounds pretty good!
You never get all of the oil pulling the drain plug, since the hole isn't the lowest point of the pan.
Clearly you guys subscribe to "The only way I have ever done this is inherently the best!" theory.
Really? Ecomodder? You guys refuse to think outside the box?!
