Old 03-21-2023, 02:24 PM   #2 (permalink)
freebeard
I blew out a sidewall, but I had to slide sideways into a curb at 30MPH to do it.
Maybe -- if you drove in a circle. Most turns are momentary.
Rather than sheet aluminum, maybe Derlin:
https://www.mcmaster.com › acetal › material~delrin-acetal-plastic
Delrin | McMaster-Carr
DelrinŽ Acetal AF Resin Sheets and Strips The addition of PTFE provides a more slippery, wear-resistant surface than standard DelrinŽ acetal resin. It's commonly fabricated into pump components, gears, and bearings. Slippery Wear-Resistant Easy-to-Machine DelrinŽ Acetal AF Resin Tubes
Cd (03-23-2023)
