Old 03-22-2023, 04:01 AM   #184 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by FlashStopFall View Post
I had put a random small resistor inline with the injector signal instead of a 50k, because 50k made the signal too weak. I replaced it with a 10k and it works perfectly now.
That's great to hear!
What did you say your vehicle was again t vago? All I had to change in the settings were my speed pulse count, I didn't touch usec/gallon but so far the mpguino seems spot on!
I had a 2005 Dodge Magnum SXT with the 3.5L V6. It's very possible it shared the same fuel injector part number with your Jeep, at least from the factory. Not surprised about the VSS count.
Keep us posted about your MPGuino! As always, it is a work in progress.
Speaking of which - I have begun to split apart the file into smaller chunks, stored in the mpguino_tav directory of my repository. It is available here -> https://github.com/tvago1972/MPGuino
The Following User Says Thank You to t vago For This Useful Post:
FlashStopFall (03-22-2023)
