Old 03-22-2023, 08:46 AM   #9 (permalink)
j-c-c
It will depend mostly on the shape and inclination of the windscreen, but it's still most often way more efficient than having no windscreen at all. Even if the windscreen is a little more upright, like you'll be more likely to see on a Harley, if it's quite curved, may deflect better the air than the rider's torso would when directly exposed to the air flow.
My thinking was a rider has to be completely a high drag obstruction, and a small to medium windscreen might deflect enough air smoothly to lower the total overall drag, even by adding some drag of its own, ideally there would be a sweetspot, but I'm not reading that so far with these replies.
