Old 03-23-2023, 02:56 AM   #186 (permalink)
t vago
MPGuino Supporter
t vago's Avatar
iNXS - '10 Opel Zafira 111 Anniversary
Suzi - '02 Suzuki Swift GL
Originally Posted by FlashStopFall View Post
That’s sweet!! Thanks for putting the code on GitHub, that’s way easier.
Yep, that's why I moved the code there. Imagine taking a 4 year long break from working on a program with 10K or so lines of code, and then trying to dive back in! Ugh...
Do you happen to know off the top of your head what your v6 used g/h at idle? I’ve got the 4.0 inline 6, relatively similar, but I use 0.8+ g/h all the time at idle. I think my first ecomods to the jeep besides the mpguino will be lowering that number.
My Magnum originally had a 3.5L V6, and it had an idle consumption of around .6 to .7 gph, IIRC. I later on swapped in a stick shift to replace the automatic tranny that decided to grenade itself, and then later on swapped in a 4.0L V6. When I sold the Magnum, it was getting idle figures of 0.55 to 0.6 gph. I think that was mainly due to my ditching the automatic.
