Old 03-23-2023, 12:45 PM   #187 (permalink)
FlashStopFall
EcoModding Beginner
WJ - '03 Jeep Grand Cherokee Laredo
Team E85
90 day: 17.28 mpg (US)
ZJ - '94 Jeep Grand Cherokee Laredo
Originally Posted by t vago View Post
Yep, that's why I moved the code there. Imagine taking a 4 year long break from working on a program with 10K or so lines of code, and then trying to dive back in! Ugh...
My Magnum originally had a 3.5L V6, and it had an idle consumption of around .6 to .7 gph, IIRC. I later on swapped in a stick shift to replace the automatic tranny that decided to grenade itself, and then later on swapped in a 4.0L V6. When I sold the Magnum, it was getting idle figures of 0.55 to 0.6 gph. I think that was mainly due to my ditching the automatic.
Gotcha. I’m going to be starting a new project this summer, a ZJ, and I’m planning to manual swap that one. On my current Jeep the alternator squeaks a bit, I believe it’s causing some drag, I think it will be interesting to see the g/h with the serpentine belt removed.
On another note, here’s my mpguino setup! I would like to design my own pcb to put the whole thing together compactly, but I’m just learning how to do that.
The Following User Says Thank You to FlashStopFall For This Useful Post:
t vago (03-24-2023)
