Old 03-23-2023, 07:56 PM   #6 (permalink)
oil pan 4
Basjoos used aluminum conveyer belt rollers attached to the inside of the wheel covers on Aerocivic. There was no frictional surface, the rollers simply rolled along the sidewall when turning, though the rollers he used were the less expensive ones (without bearings) so they're a bit noisy.
It appeared to work.
