Old 03-24-2023, 09:37 PM   #67 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Close, but not quite there yet. You still distinguish between walls and ceiling. If they are 'inflated' to a hemispherical shape, the internal air currents will distribute and conserve the temperature differential versus the outside, before any consideration of layering insulation and thermal mass into it.
5V,12V, 120VAC and a buck converter to 400V for the car charger.
I would be interested in what you mean by hemispherical and the internal air currents. As far as I know the cheapest way to build is a two story home. It cost around 60% of the cost to build as a one story home of the same square feet. For the most part my comment was that its more effective to build thicker walls and even out your insulation around the entire envelope not pile it in certain areas. It begins to be like comparing 40mpg vs 60mpg vs 18mpg and 38mpg etc...
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
