Old 03-25-2023, 03:39 PM   #1 (permalink)
oil pan 4
Tough little generator build
I got a $10 single phase alternator, 2 pole, 120v, 29amp, 3.5kw, floating neutral, taper shaft about 100hrs on it. Came from a yanmar 320cc diesel generator. The diesel engine is toast.
Should take about a 6hp engine to crank out that much power. Ebay sells really cheap taper shaft engines.
I think I found a 10hp Tecumseh that should fit.
Why would I put a 10hp engine on a 6hp generator?
For motor starting. And if it doesn't fit I'll make it fit.
I found that electric air compressors, welding machines, pumps and generators are natural enemies.
Now putting a 10hp motor on a 3.5kw generator could melt the generator so I'll have to give it a breaker or fuse.
Ecomods, I'll make it variable speed so I can run it at say 30, 50 and 60hz.
