Old 03-26-2023, 12:43 PM   #75 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
As I mentioned, I drained the rest of the oil from my Camry into a disposable pie pan, and used the Oil Udder to remove the filter, but oil still spilled all over, so I looked up a WatchJRGo video, where he mentioned the solo cup technique.
If I'm understanding you correctly - when you remove the oil filter oil spills all over as you spin it off. That happens. The easiest way I've found to prevent that is to poke a hole in the bottom of the filter with a screwdriver or awl and let the oil drain out before spinning the filter off.
As other's have mentioned - put down cardboard under the car when draining and then under your containers when pouring from your drain pan to container.
I have zero experience with online dating apps but from listening to friends they are basically worthless. You may try meeting people the old fashion way - in person. Surely Show Low has some sort of activities or clubs you could join that might have some singles.
And Happy Birthday
The Following User Says Thank You to JSH For This Useful Post:
Xist (03-26-2023)
