Old 04-03-2023, 01:09 AM   #6 (permalink)
cRiPpLe_rOoStEr
You could try a thinner head gasket to bump up the compression slightly. This may slightly alter mechanical timing (more slack in the timing chain taken up by the tensioner).
Unless the ethanol content of the gasoline is increased, I'd take bumping up the compression ratio with a grain of salt.
