Old 04-03-2023, 02:32 AM   #84 (permalink)
cRiPpLe_rOoStEr
They are built the same here as in Brazil, except we cut every corner we can to shave pennies off every piece.
Well, sort of... I don't see much usage of synthetic foils for added insulation in Brazilian wooden houses, which are mostly single-walled, yet thickness of the planks may vary considerably. And nowadays, most new wooden houses are assembled from prefabricated kits, a method which had also been more common with prefabricated houses made out of moulded concrete which are an alternative to brick-and-mortar.
We dont use stone or brick because the proper preparation work and materials, labor to install is double the regular rate per square foot.
The construction site always becomes a mess, and it's much more of a PITA when it's a space constrained site.
