Old 04-04-2023, 12:25 AM   #8 (permalink)
serialk11r
If the head is off, you can look into raising the compression ratio by milling it. I remember asking a shop a long time ago about doing that to a 1ZZ and they said you can take a decent amount off (but like all engines, you would mess up the timing chain geometry a bit so realistically not much can be taken out). I highly doubt you'll find anything in cams.
2ZZ water pump with slightly bigger pulley will save a little bit of power but you probably won't get your money back for a long long time.
