Old 04-04-2023, 04:37 AM   #10 (permalink)
cRiPpLe_rOoStEr
Most OEM designs have some safety margin built in with regards to ignition timing, so a quarter or half point of compression isn't likely to cause ignition retard.
Instead of how the ignition timing would compensate for the slight increase to the compression, I was thinking about the EFI enriching the mixture
