Old 04-05-2023, 08:55 PM   #1196 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
What was wrong with that?
I saw a house built around the trailer.
The trailer was still inside!
If I could only buy a trailer I often wonder about adding onto it, with presumably two stories.
I guess that when I could afford to add onto the addition I replace the original home.
If the property is big enough you could build a house on another part, but then you might end up with a house on a weird location on your property.
Move the mobile home out of the way, connect it there, and built a site-built home in the original spot?
I don't think you could build another story above a trailer unless it was a house on stilts. Even adding drywall on a trailer's ceiling can wreak havoc on the frame due to that extra weight.
