Old 04-06-2023, 02:35 AM   #98 (permalink)
cRiPpLe_rOoStEr
If I were building a house, I'd have conduit running to all the rooms so I could add anything I wanted in the future easily. PVC costs next to nothing and is super easy to install. Crawling around in the attic when it's 130 degrees up there, trying to drill a hole down and hoping you found the small gap where the wall studs are is insane.
Not to mention how dangerous it is to crawling around in the attic of a house built in a half-assed way, which also is the case for McMansions such as the one where a Brazilian TV host had an accident in 2019 and died some days later.
