Old 04-08-2023, 01:43 AM   #238 (permalink)
cRiPpLe_rOoStEr
The only way in which a hybrid makes highway cruising more efficient is by downsizing the engine, thereby working it harder at steady cruise speed.
Well, sort of... It's often mentioned the planetary gearset of a Prius for instance makes it easier for the electric motors to provide an effect similar to a CVT, but in the end the electric drive may also act sorta like a booster, so even at a more constant load the ICE won't be so likely to seem so underpowered even at a high speed.
