Old 04-08-2023, 09:57 PM   #25 (permalink)
Cd
Ultimate Fail
Cd's Avatar
This is version 2.0 of the wheel cover test.
Aluminum is in place, but everything is just held on with scews for easy changes.
Even with everything sloppy, I was surprised at how little noise I hear in turns.
The final version will have the aluminum riveted on, and there will be a layer of foam behind it to absorb noise.
So far, it seems to work well.
Initially, I had two braces coming down from the hinge assembly, but to my surprise, it seems to function fine with only one brace on the and one spring.
( Will add another brace regardless, but may go with a single spring.
I took the car on a short drive around the apartment complex, and tried to make extremely wide turns ( People no doubt thinking I was drunk )
I also drove at a good speed over speedbumps.
What do you guys think would make a grinding noise once I apply brakes ? The wheels were straight at the time, and the front end was not compressing downwards, since I was only going maybe 5mph.
Also, I did not hear this same sound when going quickly over speedbumps.
Looking at the skid marks on the aluminum doesn't give me a clue.
Strange, eh ?
BTW, I think I'm going to bang up the back of the aluminum some more.
I noticed there is less surface area that makes contact with the tire that way.
I was thinking that this would also add strenth to the metal, versus a flat piece of aluminum.
Less noise too.
ID:	33683   Click image for larger version
ID:	33684   Click image for larger version
The Following User Says Thank You to Cd For This Useful Post:
freebeard (04-08-2023)
