Old 04-09-2023, 02:09 AM   #26 (permalink)
cRiPpLe_rOoStEr
Originally Posted by Cd View Post
I think I'm going to bang up the back of the aluminum some more.
I noticed there is less surface area that makes contact with the tire that way.
I was thinking that this would also add strenth to the metal, versus a flat piece of aluminum.
Less noise too.
Not so sure about it increasing the strenght of the metal, most likely it won't work that way, but getting rid of contact with the tire is a desirable feature, as a tire rubbing the aluminium will increase drag.
And even though I'm not sure it would also decrease noise, most likely it would. In some buildings, the ceiling shaped with many convex surfaces is used as a sound-deadening measure.
Cd (04-09-2023)
