Old 04-11-2023, 05:47 PM   #1 (permalink)
Phase
Phase's Avatar
Black Bullet - '19 Hyundai Ioniq Hybrid Blue
will my tires pop?
so if im running 40 psi on my tires that have a max inflation of 44psi
and i drive to phoenix where its 100 degrees, based on the temp diff, my baseline cold pressure will be 45 psi. driving around the numbers raise 2-4 psi depending on surface temps and speed. that means my tire psi may hit 47-49 psi when they are rated at 44. i would be driving solo without a fully weighed car though
will i get a blow out?
