Thread: Aprilia SR 50 R
Old 04-11-2023, 08:09 PM   #21 (permalink)
JacobLeSann
On word of the power valve, I’m not sure. Maybe? As of current, I have a beginner’s understanding of this scooter’s mechanicals. Maybe a year from now I’ll have better knowledge to answer that. I’m new to motorized bikes of any sort.
A super helmet! That’s the future right there, like the Rocketeer or something! Haha, in seriousness though I have considered helmet mods. I designed an aero spoiler for a bicycle helmet and a similar spoiler for my backpack; pretty funny ideas.
Yes, the spoiler is not too effective, but I’d think it has some use. After seeing it being called useless I’m considering adding something to stabilize airflow behind my head. At the same time I kinda like the “shelf” and think it looks ugly with a turtle-deck there.
Bleh. Even uglier than current.
Here’s some photos of the bike right now. I redesigned the rear into more of a tail.
On the left, there is a flared portion that fits over the swing arm. I’ve made a little intake duct to allow air to flow into my aftermarket air filter. This seems to work well and I’ve noticed it is clean in there. I put a little too much taper at the rear but I made sure to have a sharp edge all around for good flow separation.
On the right, I’ve flared out the panel to allow the exhaust to fit inside. There’s an upper intake (crude) behind the foot board and a lower intake (better) below. I designed these to allow airflow into the fairing to cool the exhaust as well as blow out the fumes coming out of the bottom. There’s a little white patch behind the duct, and that’s a fix for the original design, where I ended up blocking the exhaust’s down-spout. I noticed a cigarette smell while idling at a stop light. I added a patch with a slight flare and then cut out the bottom area of the fairing to fix that.
I tried to add what I could to the bottom and inside of this fairing, in an attempt to try and get some flow attachment there.
At the rear, I added a separation edge around the exhaust “box”. Whether this helps (by giving a bit more guidance between the air coming off the sides and the air dumping out the vents), or just looks cool, I’m not certain. I think it looks both like a toaster as well something out of Star Wars.
I actually just got home from my evening commute, this time on the bike. I rode the same route yesterday, and then went cruising around town and some country roads. Screwing around between 0-50 km/h to 75-90 km/h, I travelled 60 km and knocked one bar out of the gas gauge. If that’s to believed, I spent a good 1.12 litres. I think that’s great!
I plan to keep riding the bike while I remove the fairing sections and paint them. I think this can help give me better insight into the difference made.
ID:	33687   Click image for larger version
ID:	33688   Click image for larger version
ID:	33689   Click image for larger version
ID:	33690   Click image for larger version
ID:	33692   Click image for larger version
The Following 2 Users Say Thank You to JacobLeSann For This Useful Post:
freebeard (04-11-2023), Joggernot (04-12-2023)
