Originally Posted by redpoint5
I believe drag is proportional to density (someone correct me if I'm wrong).
This density calculator can give air density at any given elevation and temperature.
https://www.mide.com/air-pressure-at...ude-calculator
I used 1 ATM (sea level) and found that at 10,000ft density is 0.69 ATM.
I expect a 30% reduction in aerodynamic drag at 10,000 ft.
Regarding gasoline consumption in a modern vehicle; it's proportional to the amount of power needed. It takes the same amount of fuel to produce 50 horsepower regardless of elevation. The only thing the elevation does is require a wider throttle opening for any given horsepower compared with sea level, but the fuel consumed for that given horsepower is the same. The only time elevation becomes a limiting factor is at wide open throttle. You will generate more peak power at sea level than at elevation.
maybe that could explain why when im driving thru central utah at 6k feet, i get 44-46 mpg with cruise control set to 89/90mph...
