Thread: Aprilia SR 50 R
Old 04-15-2023, 11:24 PM   #23 (permalink)
JacobLeSann
Finished up the first proper tank fill. I am still proclaiming my figures as estimates (as this thing is hard to get mileage measurements from), but it looks like I went 248.9 km (154.65 miles) and burnt away 5.83-6 litres (1.54-1.58 gallons). Total looks to be 97.87 or 100 MPG. Reason for the difference in range is that I don’t know exactly how much is left in the tank.
That’s great! I spent the first part of the tank ripping around the streets testing out the bike, the second part of the tank rushing at 85 km/h (9500 RPM) to work, and the last third cruising the highways late at night. I wasn’t fully trying to hypermile the tank and didn’t have my bodywork for the last half.
As for the lack of aero-mods, I noticed the bike is louder without. There’s a good bit of whistling going on. It seems I couldn’t quite get over 86 km/h and the engine was really screaming.
The handling is just fine. The appeal of this seating position versus lower feet-forward bikes is that I can lean forward and stand up. Ive managed to hop over some potholes and ruts in the road, fully lifting the bike off the ground a bit. Shifting forward allows nimble handling; I’d say as nimble as the original seating position. I’ve noticed that sitting so low in a flat seat means I need to lean more to make the sharper turns. More input needed to make the same adjustment; it’s like balancing a broom handle versus balancing a hammer. This could be a problem if I was on a race track as the tread wants to run out in sharp high-speed turns, but it’s a 50cc scooter so no biggie.
Anyhow, those are my observations. I’ve revised some of the bodywork and I’ll update results on that soon.
The Following User Says Thank You to JacobLeSann For This Useful Post:
freebeard (04-16-2023)
