Old 04-19-2023, 08:18 AM   #10 (permalink)
Blacktree
Blacktree's Avatar
The Prius Experiment - '07 Toyota Prius Base
90 day: 58.52 mpg (US)
As mentioned above, the max tire pressure printed on the sidewall is cold pressure. And it's mostly for stuff like driver/passenger comfort, proper tire wear, etc.
If you keep the tires overinflated for a long enough time, you'll eventually get increased treadwear in the center of the tire. Otherwise, you should be fine.
On a side note, the tires on my Prius have a max rating of 44 psi. But stock pressures are 35 psi front / 32 psi rear. I noticed the tire wear was uneven, more wear on the outside edges. So I increased the pressure to 40 psi front / 37 psi rear. People lost their minds! I was getting youtube comments saying the tires are gonna pop, I'm gonna have an accident because the handling is ruined, etc. People are funny.
The Following User Says Thank You to Blacktree For This Useful Post:
Dodge 1996 4x4 Dan (04-21-2023)
