Old 04-19-2023, 03:37 PM   #11 (permalink)
freebeard
The problem is two-fold:
  • You don't understand what everyone else knows:
But the concept it's a simple sum, then keep going to increase the phenomenal interaction.
Let me make a simple caparison: One Turn is One step, OK, Well in this particular case.
When you do One Turn is One Step, And Then is another turn are gone to be Two Steps.
And in the next turn are gone to be Four steps, And the next Turn are gone to be 8 Steps. Etc...
Really to to be able to explain it, needs to invent a new Mathematical Signal. Brand New.
I Tell You. Its Like That.
What you describe is binary notation.
Binary number
A binary number is a number expressed in the base-2 numeral system or binary numeral system, a method of mathematical expression which uses only two symbols: typically "0" and "1". The base-2 numeral system is a positional notation with a radix of 2. Each digit is referred to as a bit, or binary digit. Wikipedia
  • You don't express yourself in term others can comprehend.
My best suggestion? ChatPDF. duckduckgo.com/?q=.chatpdf&ia=web
Feed it your writing and let it explaln everything to everyone in whatever language they interrogate in.
You can't be wise and in love at the same time. -- Bob Dylan
