Old 04-19-2023, 07:47 PM   #13 (permalink)
freebeard
Your asking the window to do the job of a lantern or cupola.
The home my parents built in 1980. Two solutions employed, the dormer and the window that projects through the eave line [don't know the name, it was popular locally 150 years ago].
Other solutions exist.
https://www.veluxusa.com
VELUX Skylights | See our selection of skylight windows
The VELUX Sun Tunnel® Skylights bypasses all obstacles, using an adaptable reflecting tube to direct daylight into every area of your home. The effect is brighter and more comfortable living areas. Browse Sun Tunnels Roof Windows Put fresh air at your fingertips with VELUX roof windows.
_________________
Methods:
  • I'd create two or more forms (plywood or whatever) and cast shallow hexagonal pyramids.
  • Transport them to the site and asemble into compund curve 1/5th hemispheres.
  • Erect a mast at gound zero, array the five panels around it so their adjacent corners can be bound.
  • All five are winched upward until they interlock and are suspended above the ground; ground anchors are attached with clevises to align and apply tension.
  • The mast gets a spiral stair, the pentagon opening gets a[n f-in] yurt, and the five triangular openings at ground level get a deck that hinges upward into a storm shutter.
From 2015:
