Old 01-24-2008, 09:19 PM   #31 (permalink)
Big Dave
Big Dave's Avatar
The Red Baron - '00 Ford F-350 XLT
90 day: 27.99 mpg (US)
Impala Phase Zero - '96 Chevrolet Impala SS
90 day: 21.03 mpg (US)
I beg to differ about the "fast back crap." Mine works nicely.
Weight is important but if you intend to use a pickup as a pickup, it becomes a special case.
Trucks are for hauling stuff. Trucks should be evaluated like aircraft - loaded to max gross. If that is the case, you can remove weight from the truck but you don't remove any weight from the vehicle. You just add more payload capacity.
2000 Ford F-350 SC 4x2 6 Speed Manual
4" Slam
3.08:1 gears and Gear Vendor Overdrive
Rubber Conveyor Belt Air Dam
