Old 04-24-2023, 11:05 AM   #27 (permalink)
Blacktree
Blacktree's Avatar
The Prius Experiment - '07 Toyota Prius Base
90 day: 58.52 mpg (US)
Unfortunately, the gas engines in these cars aren't very fuel efficient. For good fuel economy from the factory, you'd have to get a TDI.
But since your fuel economy is fairly low, marginal utility will be your friend. For example, if you can get 5 more mpg from your car, the money you save will be greater than, for example, taking a 40 mpg car to 45 mpg. Since it's burning so much gas, every mpg you can squeeze out of it will make a difference.
That said, you might want to do a cost-to-benefit analysis of a more fuel efficient car vs this one. Figure out how much money you'll spend on gas in a year. Then compare it to how much you'll spend if the car had 40mpg or something like that. You might find that a 40mpg car will pay itself off in fuel savings after a few years.
The Following User Says Thank You to Blacktree For This Useful Post:
V6MustangFTW (04-29-2023)
