Old 04-28-2023, 01:28 AM   #275 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
Originally Posted by Phase View Post
well i got no warranty period, so everything is fair game now i suppose...
Yes, and if you break it you pay to fix it. Are the tiny possible fuel savings from covering the exhaust worth the risk of killing a harness and sensor that likely cost hundreds of dollars? That is for you to decide.
Manufacturers are risk adverse. We do millions of dollars of testing to reduce warranty costs and also have very little tolerance for warranty issues. At my company a 1% failure rate will get a problem escalated to the CEO. For any company a 4% failure rate on a powertrain or emission item triggers a mandatory recall.
Steady cruise is easy. Shedding heat is hard when the load is high and the speed is low, like ascending up a mountain.
Steady state can be easy or a pocket of still air can cook components. I've seen it happen.
The Following User Says Thank You to JSH For This Useful Post:
redpoint5 (04-28-2023)
