Old 05-01-2023, 02:30 PM   #2 (permalink)
freebeard
Look for this symbol and sort it out. The rest can be ground up and used for a paving amendment or something.
The HDPE softens at 375°. When it's the consistency of bubble gum (wear gloves) in can be formed, extruded, machined, drilled & tapped, etc. Press molds work well, or a rolling pin on side rails.
Best answer find a [best] use for it.
https://www.lifewire.com › diy-filaments-for-your-3d-printer-2245
How to Make DIY Filament for Your 3D Printer
18 Jan 2022Use a Filament Extruder to Make Your Own Filament Along with a filament extruder, you'll need heavy-duty scissors and a rubber mallet. The exact process depends on the extruder you use. Here's a look at the general method. Gather and collect your failed prints and sort these by color.
https://hackaday.com › 2020 › 07 › 17 › make-your-own-filament
Make Your Own Filament | Hackaday
a filament extruder using a high torque induction motor and gearbox that was locally sourced. He argues that shipping heavy gear around would make a similar extruder commercially unattractive. He...
https://www.youtube.com › watch?v=Eecbdb0bQWQ
How to Make free & easy filament for 3D printer at home
**** Start making your own filament maker right now ***watch these videos in order:#1 Multicolor printing : Bott...
