Old 05-01-2023, 04:14 PM   #11 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
If the antenna is to be removed, and the top center is the optimal location, why not a flush threaded [electromagnetically isolated] hole?
That could very well work, as long as you don't have any "tuning circuits" in the bottom of the antenna that require a connection to the ground plane.
For an example, a 5/8's wave antenna may have an L circuit, which would need to be connected to both the monopole and the ground plane.
You could also just use a tuner instead, placing the tuning circuit farther away (so more loss over the coax), but still should work about the same.
A NMO mount isn't very tall. That's what I use.
The Following User Says Thank You to Isaac Zachary For This Useful Post:
freebeard (05-01-2023)
