Old 05-02-2023, 11:52 AM   #186 (permalink)
Blacktree
Blacktree's Avatar
The Prius Experiment - '07 Toyota Prius Base
90 day: 58.52 mpg (US)
I decided to swap the mirrors side-to-side, just to see what they look like. I think this is how they're supposed to be installed. But IMO they resemble dog ears.
The "angle of the dangle" is built into the mirror base. So I think I'll rotate the mirror bases 180 degrees, to angle the mirrors back up.
Edit to add: I probably should explain there's a swivel joint in the mirror base, so you can pivot the mirrors up & down. But that should also allow me to rotate the base 180 degrees.
BTW, yeah I installed fog lights. But they're not wired up yet. I'll do that when the front bumper is off, for "grille block 2.0"
