Old 05-03-2023, 04:25 PM   #23 (permalink)
Isaac Zachary
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
Originally Posted by ai4kk View Post
So on a tapered cylinder like an antenna, would I just use the average diameter?
Correct. I'd just measure the middle if it looks like the taper is the same down the whole whip.
How about a flat foil bow tie dipole? Or even better: inside the vehicle attached to the window?
Dipoles tend to be a half a wavelenghth instead of a quarter like with a vertical monopole ground plane antenna. So an 8.5 ft antenna now becomes a 17ft antenna. You'd need a prettly long window to put that on.
