Old 05-08-2023, 04:06 PM   #7 (permalink)
aerohead
' K'u'chemann carrots'
1) The 'spacious interior' is interesting.
2) It looks as if, in order to satisfy rollover and roof-crush requirements, that Toyota raised the rear hatch hinge mechanism above the roofline, creating an objectionable 'bulge', then to deceive the eye, installed the 'carrots. originally designed for non-laminar wing, transonic wave drag mitigation ( Airbus, Boeing, Convair, Fokker, etc. ), as a styling trick.
3) For torsional stiffness, it's important that, in a rollover, that the hatch remain closed, adding strength that would be lost, should the hatch come open.
Next time you fly, sit behind the wings and look for these:
'anti-shock fairings'
'Flap track fairings'
'Whitcomb bodies'
'pods'
' Wing flap jacking-screw transmission housing'
'(Dietrich) K'u'chemann carrots'
While the rear shelf will 'burst' longitudinally-attached vortices from below, the 'carrot' is positioned exactly where the 'top' of a vortice would initiate.
At Cd 0.29, the RX 450e isn't any paragon of low drag, however, had the CFD and wind tunnel folks not 'played around' with the hatch area, range would have suffered even more.
I just wouldn't want to be a motorcyclist colliding with the back of the car.
BamZipPow (05-09-2023), freebeard (05-08-2023)
