Old 05-10-2023, 01:57 AM   #45 (permalink)
cRiPpLe_rOoStEr
Most newer engines run a higher static compression ratio than can be readily (or efficiently) controlled by ignition timing alone.
Even though some flexfuel engines didn't resort to such an "extremely" high compression a few years ago, and Fiat introduced intake and exhaust VVT to a SOHC engine in the "people's car" segment when it released the GSE/Firely 3-cyl 1.0L and 4-cyl 1.3L in Brazil. Some folks often say the VVT was meant to provide a lower dynamic compression, yet it doesn't seem to be really the case, otherwise the power and torque difference would be much greater on gasoline compared to ethanol.
Sufficiently advancing or retarding ignition timing effectively limits how much air gets into the cylinder, reducing the absolute peak cylinder pressure to a manageable number, while also allowing for very high expansion ratios.
AFAIK adjusting the ignition timing works to overcome turbo-lag too, but I'm not sure why it would limit how much air gets into the cylinder.
