Old 05-10-2023, 10:51 AM   #208 (permalink)
Blacktree
Blacktree's Avatar
The Prius Experiment - '07 Toyota Prius Base
90 day: 58.52 mpg (US)
Basically, I'm going to use them like DRLs. But technically they might not be considered DRLs, because they don't come on automatically with the ignition. They come on when I turn on the running lights.
They're setup like that, because I want to be able to turn them off. But I don't want an extra switch to contend with. Having the fog lights piggyback on the running lights jives with my feng shui.
Also, the dimmer knob is basically a "set it and forget it" type of thing. I'll fiddle with it until I find the optimal brightness, then leave it there. It's the same thing I did with the Jetta. And it worked nicely.
The Following User Says Thank You to Blacktree For This Useful Post:
freebeard (05-10-2023)
