Old 05-15-2023, 01:11 PM   #10 (permalink)
aerohead
3D Model
Behold the singular power of proprietary software.
A 'photograph [is not equal to] parametric data.
Right, the model is based upon 3D scans, including grille, the cowl, everything under the hood, inside the wheelhouses, body gaps, hoses, brake lines, wiring harness, cables, all suspension components, chassis pan, frame rails, exhaust system, fuel tank, the underbody, air-curtains, extractor vents, spare tire, etc., not photographs.
And at $20,000, the results would have enough 'noise' that the the 'signal' from some aerodynamic modification could be 'lost'.
