Old 05-17-2023, 01:06 PM   #8 (permalink)
hayden55
Sport Utility Prius - '10 Toyota Prius II
90 day: 52.98 mpg (US)
300k Sequoia 4WD - '01 Toyota Sequoia Limited 4wd
90 day: 20.19 mpg (US)
Go for the highest load you can get with staying in closed loop so it doesn't go into enrichment. Typically try to target 2100 as your mid point in rpms. Between those rpms and high load it should reduce a lot of pumping losses associated with the throttle
"I feel like the bad decisions come into play when you trade too much of your time for money paying for things you can't really afford."
The Following User Says Thank You to hayden55 For This Useful Post:
Blacktree (05-17-2023)
