Old 05-22-2023, 12:39 AM   #1 (permalink)
JSH
AKA - Jason
JSH's Avatar
90 day: 17.3 mpg (US)
New Heat Pump Hot Water Heater = All Electric Home
I've been looking at Heat Pump hot water heaters for a few years now but couldn't see spending the money to swap out our gas water heater. Well that was taken care of for us when it decided to fail in a spectacular fashion. The plastic drain valve failed, shot across the room, and the water heater sprayed gross water full of mineral deposits all over my BMW. (It took 3 washes with the last using a diluted vinegar to get the deposits off the bike)
So this weekend I spent our anniversary swapping out a water heater. The hardest part was finding fittings that would work for the condensation drain.
The new Rheem Protera 50 gallon water heater will work out to be $700 after incentives. ($1700 - $700 from electric utility - $300 Federal tax credit. The energy star label says it will use $117 of electricity a year vs the $330 a year on the label for the old water heater. (We actually spend $209 a year for natural gas)
Failed plastic drain:
My motorcycle after the rupture:
New water heater:
ID:	33815   Click image for larger version
ID:	33816   Click image for larger version
The Following 2 Users Say Thank You to JSH For This Useful Post:
Isaac Zachary (05-30-2023), redpoint5 (05-22-2023)
