Be sure that Hyundai didn't intentionally 'engineer' the gaps to provide cooling- air to electronic heat-sinks behind those areas.
You'll be looking for anything attached to a raised, ribbed-aluminum structure, supporting a 'black-box', with a wire loom attached.
Power devices contain switching transistors and diodes which must expel heat in order survive.$$$$$$$$$$$$$$$$$$$$$$$
![EEK!](/forum/images/smilies/eek.gif)
