Thread: Shavingcrete
Old 05-28-2023, 10:27 AM   #164 (permalink)
Piotrsko
Romans didn't use rebar. Everything they built was in compression which is limited by the compressability of the base rock. Pantheon with its ocular roof is prime example, used mostly continuous since built. Columns out front are made of solid marble which is probably the weakest thing of the structure.
Probably helps that Rome doesn't get much freezing
